LEDs and electronic flashers
76-77-78
Garrison ND
Ethan
Im looking to switch my tail lights and turn signals over to LEDs and was wondering where to get an electronic flasher to work with LEDs. And also if you guys had any LED replacement bulbs you like
Thank in advance
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I'm gonna be doing this mod soon and I decided to try this ebay flasher:
https://www.ebay.com/itm/2-Pin-Blad...var=521247018817&_trksid=p2060353.m1438.l2649
There are others but I like the availability of the screw adjuster.
As for LEDs I would go with a higher SMD (surface mount diode) number for better visibility. Thats worked for me on multiple vehicles. Also if you have a colored lense that you want to flash make sure that the LED behind it is of the same color. Amber lense = amber led, red lense = red led.
The more light emitting to the refracting surfaces the more light emission you'll get from your housings.
People like to buy to buy from superbrightleds, I havent had a problem buying cheapo from ebay based on SMD count. Longevity can and will vary based on your electrical system condition.
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
I bought ebay specials for the leds, but they ended up flickering after a while. Plus the color isn't always the same if you get while. Some are a pure white where others would be closer to daylight.
For flashers, I purchased the wrong pinout one from superbrightleds. Would've worked great if i ordered the correct one. The rear bulbs i got for the tail/brake lights were actually dimmer than the halogens. The load caused by the standard bulbs in the rear was enough to keep from needing an electric flasher.
I also used switchback turn signals (white on, amber flash) which worked well, but it ended up with too much white in the front (headlights, turn signals, and my 5 hellas) so i switched back in the amber lenses and standard turn signal bulbs.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Thank in advance
Instead of replacing the incandescent bulbs in the tail lights, I wired up several led strip lights in series (12volt strip lights, white from ebay for $12 for a 5 ft roll). I tapped into the power feed from the incandescents. No need to replace the flasher at all since I did this. The front marker/turn signals were replaced with a single amber led..and again...no need to replace my flasher. Too often the led replacement bulbd end up going bad, losing one led at a time. I had that issue and came up with this as a solution. If you know how to solder and are patient, this is an option.
spenser21
a
a
I ended up having a half hour internet chat with someone at https://www.superbrightleds.com/ ... actually a very informative conversation for me, he set me up with turn signals and brake lights as well as the new relays to go with the bulbs and style truck I had
76-77-78
Garrison ND
Ethan
https://www.ebay.com/itm/2-Pin-Blade-CF12ANL-01-Adjustable-Electronic-Flasher-Relay-Fix-LED-Turn-Signal/222378194057?ssPageName=STRK:MEBIDX:IT&var=521247018817&_trksid=p2060353.m1438.l2649
Ok I was looking at superbrightleds but they are on the high side so I’ll probably go with eBay bulbs. and if they last awhile great if not I will probably save for the lmc truck led housing or just buy good quality replacement led bulbs. But I finally got my new pickup box put on so it’s accessory shopping time.
johnalen76
