just thinking
SWSS
NETN
Anthony
alright guys, I am doing some long term planning.
1. Does the rear section of a sqbody sub narrow over the rear axle as the truck frame?
2. if so is is feasible to look at narrowing the rear end and tucking the DRW under the body, like a "pro-street" tucked under dually?
3. I dunno, i like number points.
My final plan is to dual out a flat black sub and drop in a Cummins!
What do you think will the dual tuck under?
Here are some dimension charts:
http://www.gmsquarebody.com/forum/showthread.php?t=5530
Here is a tucked dually pickup I found:
attachment.php
Discussion:
http://www.gmsquarebody.com/forum/showthread.php?p=104919&highlight=dually#post104919
Being a Burb owner spending much time repairing my inner rear wheel wells I would say there is very little room to tuck duallys too far in at least on the body. Like many a times though I could be wrong, lol.
SWSS
NETN
Anthony
thanks. I have shoved some large meats in by swapping the spring perches then adding extended rear wheel wells. Just never messed with duallies before...I guess I am going to have to do some real life measuring...
All you need is the Cab&Chassis (narrow dually) rear axle and the 1-ton spring hangers and shock brackets. Like a pickup, the inner wheel tubs will need widened some for tire clearance. I've thought about doing that myself, I think it would be really cool.
SWSS
NETN
Anthony
Thanks bucket. I have a vision of what i believe it would look like but what is reality may be different.
I may just have to tub and bag it...
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i have a set of 1 ton spring hangers and shock mounts up for sale
sallyjeank10
