- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
The other reason is, the Transfter case will hit on the bottom of the cab if it's not a high hump. Your other option is to do a 2 or 3 inch body lift. Then then the Transfer case will have enough room under the cab. However, this does make the Transfer Case shift stick a longer reach from the driver seat, which is easy corrected, especially if going with an NP205. You can aftermarket Twin Stick your NP205 and use taller sticks or put an extension on your OEM shift stick.
