Is anyone still running full time 4WD?
dhenderz
Michigan
Dennis
Interested to fund out how many (are there any?) are still running full time 4WD? Or has everyone converted to part time?
75gmck25
Northern Virginia
Bruce
My '75 GMC K25 still has an unconverted NP203/TH350/350, and it works well. Its had some hard use over the years, but still shifts well and does not make any significant noise.
Since the shaft conversion kit is no longer available, I don't think there is a good choice for conversion to PT. I've considered a swap to an NP205, but its probably not worth the effort for a work truck that is not driven that much.
Bruce
Boonie
El Dorado, KS
Brent
im still running full time in my 74 GMC. I figure if it aint broke, don't fix it. Its proven itself over many years of use, with no issues.
bft305
ME
Ben
I am still running full time 4wd and will until it blows up! Thought I am thinking about making it a twin stick set up.
Snoots
Roger
Jimmy Sierra
350 w/203
Same here. No problems.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
My 79 is still going after 300 some thousand hard miles. I know it’s had a couple motors and a transmission or two but I never heard anything from my grandpa about the transfer case or axles being a problem.
Colin
Covington, GA
Colin
K10 Silverado
350 cu. in.
My '78 is still full-time. I see no reason to change.
norman baker
ellijay,ga
norman
1976,1981,1982,1984 1985
k20 ,c10 ,c10,c20, c10
none, 250 ,305, 454, 305, 454 ,
i have a 203 in my 76 k20 , 350 automatic, i will convert to part time soon, 410 gears , 58 mph max 9-10 mpg, 1996 gm 454 tbi 50k miles to add soon. wish they still made the shaft conversion> now only spider gear. conversions
dhenderz
Michigan
Dennis
I might be interested in selling the Offroad Marketing shaft conversion I am taking out if you are interested.
scwaters
Chester Springs, PA
Sunny
K10 Shortbed 4x4
I am a relative newbie to SB. I have a 203/350 short bed. It has a Warn hubs. Without the Warn hubs is this full time? Having trouble with the 203 linkage and am planing to go dual stick this spring.
Snoots
Roger
Jimmy Sierra
350 w/203
If the hubs are locked and the TC is in the locked position, yes.
jash1990
