Is an EGR Delete Kit Worth It for Performance and Longevity?
Stoichiometric
United kingdom
Stoichio
c30
v8
Hello everyone.
I’ve been researching EGR delete kits and keep seeing mixed opinions about their benefits and risks.
Some people claim they improve engine performance, fuel efficiency, and reduce carbon buildup, while others warn about potential legal issues, increased emissions, and possible engine damage over time.
For those who have installed an EGR delete kit, what has your real-world experience been like? Did you notice a significant difference in performance or maintenance? Also, are there any long-term downsides that don’t get talked about enough?
I’d appreciate insights, especially from diesel truck owners or mechanics with hands-on experience.
Stoichiometric
United kingdom
Stoichio
c30
v8
Hello everyone.
I’d appreciate insights, especially from diesel truck owners or mechanics with hands-on experience using the SuncentAuto Cummins EGR delete kit.
thanks in advance for any help
What are you working on? I had everything written up well for a gas truck. Then reread your post and saw diesel mechanics,so I deleted everything. I'm not aware of diesel squares having egr valves.
77Dmax
vt
Joe
Eh eye.
Moderator
The "C" code (I think) 6.2's had an egr in the manifold inlet. The "J" code (again, I think) engines did not.
Old Blue 79 Scot
Pine
Zane
K10 Scottsdale
I have the same question for my ‘79 350. My EGR housing is cracked and I’d just as soon block it off instead of replacing it. No emissions where I live.
IPB13
Army
Rhode Island
Patrick
If in fact you have an 09 as your info suggests, then heck yeah its worth it. I had an 09 Duramax and the benefits were immediately noticeable. I also did a turbo back exhaust and a duramax tuners tune with several other bits, but yeah it was great.
If you actually have a C30 with the old 6.2, then I would say the same. You're motor will breath better, be more responsive, and the butt dyno might feel like you picked up some HP :D
Swapping to the J was a popular solution, hard to find though from what I recall.
winfred
port allen la
winfred
c30 v2500
i've not seen an instance where anything would be harmed by deleting egr, as long as you don't need it to pass an inspection, and if its just visual, a "gasket" cut from a beer can typically renders the offending appliance inert
Egr reduces combustion temperature. Which lowers cylinder head temperature. The lower temperature makes the engine less like to ping, so the manufacturers could could add more ignition timing,EGR goes completely away when you mash the gas pedal, so no increase in power level. And it has the added benefit of diluting your air fuel mixture with an inert gas that has no effect on combustion, meaning if you can fill 10% of the cylinder with exhaust gas you can only put 90% air fuel charge in so fuel savings and the additional timing you run on a car with EGR is more fuel savings. More ignition timing from the factory was an additional benefit the manufacturer saw with EGR.
Dammit he's working on a diesel. This applies to gas vehicles. Sorry, carry on.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Egr reduces combustion temperature. Which lowers cylinder head temperature. The lower temperature makes the engine less like to ping, so the manufacturershould could add more ignition timing,EGR goes completely away when you mash the gas pedal, so no increase in power level. And it has the added benefit of diluting your air fuel mixture with an inert gas that has no effect on combustion, meaning if you can fill 10% of the cylinder with exhaust gas you can only put 90% air fuel charge in so fuel savings and the additional timing you run on a car with EGR is more fuel savings. More ignition timing from the factory was an additional benefit the manufacturer saw with EGR.
True for a gas engine.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Same engine. Different manifold and injection pump calibration.
On a 6.2 I'd definitely lose the EGR. All it does is carbon up the intake. You could put a blockoff underneath it, or just stick a ball bearing in the vacuum line.
Joestreml
