Intermittent wipers
etedeschi72
Massachusetts
Hi,
I've got an '81 K20 that used to have the wiper switch on the dash and high beam switch on the floor. At some point before I bought the truck, the PO put in a steering column from and '84 or '85 with the wipers and high/low beams being relocated to the directional lever on the column. They only have low and high and when I turn them off, they don't go back to the rest position, they just stop wherever i turn them off. I'd like to possibly upgrade them further by making them intermittent. So, my question is, HOW? Exactly what do I need or need to do to make it possible? Any help would be greatly appreciated. Thanks
gmbellew
Kansas city
glen
suburban 1500
the intermittent is controlled by a pulse module that plugs into either side of the wiper harness at the base of the steering column. not sure if this can be readily added, depends on how PO modified the switch location.
not parking sounds like a park switch issue in the motor itself.
350 w/203
First off, I'd say that the PARK switch inside of the wiper motor cover is toast. Sometimes you can clean the contacts and that fixes it.
For the intermittant upgrade you'll need a new motor that has the circuit. Check out the GMSB TECH guides for your '81 and whatever year the pulse type came out. IDK.
etedeschi72
Massachusetts
So, I would need a new wiper motor with the right circuit, a new pulse module and a new directional lever for intermittent wipers?
dhartman
michigan
daniel
c15
Definitely want to follow this question. We to have a 80 that I would love to upgrade to intermittent wipers but leave the control on the dash were it is. I have seen that they make a relay for pre 1980 systems in LMC truck and there also is a intermittent wiper switch. I completely understand the motor aspect however could one say modify or has anyone ever done this to there truck. Do not want to go to the newer steering column I already restored out tilt column.
FenderBanger
