Intermittent stall after start when engine is warmed up
lht205
Alabama
Luke
R1500 Suburban
Long time lurker, new member.
‘88 GMC Suburban 350 TBI 700r4 2WD
Fuel pump went out last summer, replaced distributor, cap and rotor and fuel pump- ran great. A few weeks later heater core went out, few weeks after that water pump failed- replaced pump, alternator (broke mounting bolt couldn’t be removed) and radiator. Ever since then, after going on a decent drive 15-30 minutes, shut it off and go in to a store for ten minutes, when I start It up again it will either stall or drop way down in rpm then pop back up. I’ve replaced TPS, IAC, PCV, EGR Valve, MAP sensor and water temp sending unit. I’m at a loss. I have noticed that when it has stalled all the way the TBI still pumps gas through the injectors unless I shut The key off. Any other ideas?
Do you mean the injectors keep spraying with the engine off?
Sad Sack
Nebraska
Goober
C15
:welcome: ...from Husker Country!
lht205
Alabama
Luke
R1500 Suburban
Yes, when it stalls the injectors kept spraying. I should Say I only know they keep pumping from it dying when I was Walking into the house to grab something. Didn’t think anything of it but when I got Back in to restart it was flooded.
jw23655
