Interior Rear View Mirror
eskimomann209
Modesto
Marcus
Silverado dual temp compass here too. my trucks not original “stock” but everything in it is GM
yevgenievich
Place
Name
Year
Model
Size
I have a full replacement auto dim with backup camera mirror on my suburban. And couple of the compass ones laying around
yevgenievich
Place
Name
Year
Model
Size
This id like to see
Not a very good picture, but it has been good for 3 or so years now. Works great to verify hitch position or get as close as possible when backing up. When off can't really tell that there is a screen behind. It was pricy around $260. Cheaper once don't work, I had a ksource brand one that broke within a month of use and was just made poorly. I probably have more pictures in my build thread, but have to look some more for them.
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
That's some nice mirrors. I can't get my cheap ass on to stay on the fuckn windshield. Just falls off. So mine is sitting on the cab floor. Lol
Dmack
Central OR
Dave
Eskimomann, how did you get your old mirror mounting tab off? I just picked up that mirror, but am reluctant to pull my tab off my brand new windshield. They just had to make the new tab slightly bigger...
Turbo4whl
Downingtown, PA
Wayne
Heat the glass from the outside with a heat gun. Using a sharp razor scraper work around all sides of the mount. Don't forget to mark the outside where the tab is located. Lighter fluid is also a good glue solvent.
Dmack
Central OR
Dave
Thx for the ideas
eskimomann209
Modesto
Marcus
In other cars/ trucks I used the Squarebody mounting. Then others I did the heat and scraper idea. some times I’m lucky and she pops right off.
Jeff Lewis
Missouri
Jeff
Can anyone tell me the measurement in inches for stock c10 rear view mirror, from antennae button to bottom of mirror holder. Replaced windshield, wrote measurement down, lost it. I know it was either 14 or 16 inches. Thanks.
you mean the bottom of the button?
show me what you mean on these
Corvette Ed
East Tennessee
Eli
If you arent going period correct then any modern era (late 90's up) mirror would serve nicely. Gentex is a major manufacturer and adding any wiring is as simple as power (or switched source) and ground for auto dimming. Map lights and temp would be another bit of wiring but thats pretty straight forward too. If you go with a temp reading mirror try to get a package with the harness. If you go to a junk yard you should be able to snag it all for under $40.
I agree this or the one with the back up camera that clips over your old mirror.
