Im stumpped
MrMarty51
Eastern Montana
Martin
WOW,nice to see that Your truck is now running and shifting nicely,it has been great watching this thread and doing some learning Myself.
Good job for sticking with it until the problem was solved.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
That's what I have to do....hopefully I'll be smogging it this week
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
so after driving some more in the truck i noticed i have zero kick down when trying to climb a hill i have to manually shift it down a gear to get it to downshift any other thoughts?
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
So went to take my kiddo to school and the transmission is back to horrible shifts and also all the fluid is normal safe to say the spring shrank
MrMarty51
Eastern Montana
Martin
Probably be gooid to go to a reputable trans shop and see ask how the different colored springs affects shifting and get one that will suit Your driving habits then see how it shifts and functions wit the new spring.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Hey HR...have you heard anything, good or bad about that kit that keeps the trans at about 200 or so psi? gets rid of the TV cable.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ok so i spoke with a few diffrent transmission shops here in Oakhurst and in Fresno they both said very similar things the guy in Fresno said to bring it to him and he will test drive it and adjust the TV cable and he thinks he knows what the problem is and can tell me for sure if he test drives it and he also told me it would be a good ideal to add a shift kit in it from Trans Go and that will replace the spring i belive that is worn out also he said that it sounds like the TV plunger behing the spring and valve thing i had mentioned before could be getting plugged up with some kind of debris which is also what the transmission shop up by my house said to they also said i may need to rebuild it and that would range from about $1000.00 to $1400.00 and thats with the shift kit installed so now i have no clue what to do i did see some clutch debris in the pan after draining the fluid out but the fluid still smelled good so it would be nice to know what my next step should be.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Probably be good to go to a reputable trans shop and see ask how the different colored springs affects shifting and get one that will suit Your driving habits then see how it shifts and functions wit the new spring.
Ya ill be looking into that as soon as i can get some guidance from HotRodPc being that he works on these transmissions a lot more then i ever care to...
:pokeowned::emotions133::(
Jims86
Patterson,Ca
5.7 TBI
I personally would stay away from shift kits, unless its a racer.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Why is that.. everything I read on a mild shift kit is that it will prolong transmission life
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
ok so after calling around and looking info up the average rebuild cost if i take them the trans is $1300 so i found a monster transmission for $1230.45 with new torque converter synthetic fluid and TV cable shipped free all new parts good up to 600HP so now i don't know what the hell to do.....the rebuild kit alone is 509 bucks and i have no tools to rebuild it myself or i would so what should i do...
That seems to be pretty high pressure and would probably make some for some pretty harsh shifts.
I'm not against Stage 1 shift kits at all for any vehicle, especially heavier trucks or something that might be towing. In the 700r4, they actually are an improvement. The reason they claim to make transmissions last longer is snappier shifts yet not harsh until you get into the Stage 2 kits usually, which then can be hard on U Joints and Transfer Cases. Snappier shifts means less wear and less heat during a gradual soft shift.
Damn, sucks to hear this off and on again BS. It does seem you've narrowed down the problem to the TV Cable and/or TV Circuit. This is NOT a common failure of the 700r4. As much as you've struggled with this trans, I'd be about afraid to make a suggestion now and it be wrong.
So now much is the guy wanting to charge that want's to road test, drop the valve body and install a Trans Go kit? What is his price for Rebuild?
Jims86
Patterson,Ca
5.7 TBI
$700 if you can get it down to Hilmar. Includes new Converter.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
The test drive and TV cable adjustments is free :) the rebuilt however is an average of 1300
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
To install just the trans go kit they said I could do it with little to know problem or pay them 180 in labor and what ever the parts are
chubhub6969
