born2Run83
- Oct 28, 2021
- West Texas
- Justin
- GMC - C1500
- 5.3L LM7
I just replaced the starter, the one installed was not engaging the gear to the flywheel. But this did not fix the issue. However, when I turn the key from OFF to Power, then rotate to Start, the resistance is minimal.. I changed the ignition switch thinking that was the issue but it hasn’t felt the same in the key rotation since.if you went to your starter solenoid and cranked your engine (but just bypassing the column stuff) would it also do that?
