idle's ok under heavy load break's up
roy c
long island
roy
Hello I was wondering if anyone could help. I've been having the following
issue when starting the truck idel's fine, when i take off to keep up with traffic no power breaks up
i changed the cap rotor wires plugs when it warms up highway speed is ok
but i wouldn't attemp to pass anyone breaks up. i replaced the fuel pump years ago, i put a new eastern cat last june some one told me it might be the cat iwas wondering if it might be the fuel pump or the electronic points which are original when i bought the truck new. thanks roy
Boone83K10
Boone, NC
Benjamin
It could be the cat. you can get a vacuum gauge and hook it up to manifold vacuum (pcv port on carb or brake booster port) and hold the throttle open to keep RPM's steady at 2000 or so. If the vacuum goes up but slowly goes down to ZERO, you have a clogged exhaust system.
It also can be the fuel pump. Cheapest option is to buy a new fuel pump and install. If that doesn't fix it then buy a vacuum gauge (they are cheap) and do as I said. If it does as I described you know it's the exhaust.
here is a good website to show you all the diagnostic things a vacuum gauge can do.
http://www.secondchancegarage.com/public/186.cfm
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
when is the last time the fuel filter was replaced?
roy c
long island
roy
good question at least 4 years i'll change it today thanks
Jims86
Patterson,Ca
5.7 TBI
roy c
long island
roy
that was it thanks gets up and goes no problem thanks again roy
