idle around a corner kills motor
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
If I just idle through a turn with clutch in going fast it kills the motor wtf power steering pump kills it im guessing...belt to tight? Idk wierd let the clutch out itll fire right back up
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
Maybe a float issue? What about on the throttle through the same turn and the same speed?
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
If im giving it gas its fine no hesitation no bog just does it when coasting through the turn..
chevyk10
WV
Daniel
1984 chevy
k-10
In gear or not?
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
In gear ....havent tryed neutral ill see tomorrow ..ive put new clutch in recently aswell if thats what your thinking cant remember if it did it before or not.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
You have an edelbrock carb, right?
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Yes a 750 1407 converted to electric chock.. which iv had every problem with there is. I want to replace it with a truck avenger. For wheelin just need to find one cheap.
chevyk10
WV
Daniel
1984 chevy
k-10
I would borrow a different carb and try it first. Not likely you would lose fire.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Id have to buy one to test it. So it would stay on it..
Jims86
Patterson,Ca
5.7 TBI
Edelbrock is the problem...thats one of the things they are notorious for. Its a design flaw. Qjet or Holley, and be done. Truck avenger is the way to go for seriouse wheeling, purpose built.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Ya there spendy 450+ new ive seen used ones cheaper just dont have extra $ right now. Would it be best to change out the intake to holly too or does it matter
Jims86
Patterson,Ca
5.7 TBI
depends on which carb you get, but an adaptor would do the trick.
chevyk10
WV
Daniel
1984 chevy
k-10
I line Quick Fuel when you want to spend the dough for a good carb.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Drove the truck to work today it does do it in or out of gear.. you can see the tack change from driving straight to turning it drops down dosent kill it every time though just when im not paying att to it. Tighter the turn the faster it drops.
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Quick fuel they look sweet as soon as I can put a built motor in the truck. Ill try and go fuel injection try to budget it in to the cost of motor
souixchef2
