ID steering boxes 2wd or 4wd?
53chevy
pittsburgh
Luke
GMC high sierra K3500 Crew Cab
What should i look for on a GM steering box to tell if it is a 2wd or 4wd box? Thanks
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
2WD box has a threaded pitman shaft, 4WD has a notch in it's pitman shaft. Also be aware there are year breaks where the power steering lines convert to metric. Not sure what the year break is though.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Around 1980 was the transition year.
Some Dodge boxes will fit too.
2WD will NOT work in a stock 4WD.
BLAZER/JIMMY (full size) 80-82 Power Steering; 4x4
BLAZER/JIMMY (full size) 83-91 Power Steering
CHEVROLET 10 PICKUP 80-87 Power Steering; 4x4
CHEVROLET 20 PICKUP 80-88 Power Steering; 4x4
CHEVROLET 2500 PICKUP 89 Power Steering; VIN models "R/V", 4x4
CHEVROLET 30 PICKUP 80-88 Power Steering; 4x4
CHEVROLET 3500 PICKUP 89-91 Power Steering; VIN models "R/V", 4x4
GMC 1500 PICKUP 80-87 Power Steering; 4x4
GMC 2500 PICKUP 80-87 Power Steering; 4x4
GMC 2500 PICKUP 88-89 Power Steering; VIN models "R/V", 4x4
GMC 3500 PICKUP 80-87 Power Steering; 4x4
GMC 3500 PICKUP 88-91 Power Steering; VIN models "R/V", 4x4
SUBURBAN 10 80-88 Power Steering; 4x4
SUBURBAN 1500 80-91 Power Steering; 4x4
SUBURBAN 20 80-88 Power Steering; 4x4
SUBURBAN 2500 80-91 Power Steering; 4x4
Dodge will also work...
DODGE 100 PICKUP 80-89 Power Steering
DODGE 150 PICKUP 80-93 Power Steering
DODGE 200 PICKUP 80 Power Steering
DODGE 250 PICKUP 81-93 Power Steering
DODGE 300 PICKUP 80 Power Steering
DODGE 350 PICKUP 81-93 Power Steering
DODGE 400 PICKUP 80 Power Steering
DODGE 450 PICKUP 81 Power Steering
RAMCHARGER 80-93 Power Steering
TRAIL DUSTER 80-81 Power Steering
But the ratio is different.
I'd make sure this isn't 4x4 only though. Does Dodge 2wd also match GM 2wd Steering boxes?
4x4 Steer box. Notice no threads or nut as C4 said.
2wd Steer box with thread and nut.
Arm on Left is for 4x4, Right is for 2WD.
53chevy
pittsburgh
Luke
Sweet, the box i have is a 2wd with ports for the hydro assist, and im planning on ord cross over steering.
You're saying you have a 2wd box on it now? If so, someone may have already installed crossover steering. Most crossover steering systems do require a 2wd steer box.
53chevy
pittsburgh
Luke
Oh no, i had it in the garage, just wanted to make sure it was a 2wd box and not a 4wd box with ports for the hydro
Corncob
