I-Talian Tune UP
Old60Driver
1983 K20 Silverado
Houston
Michael
K20 Silverado
So, I had gotten ye old '83 running pretty decent. Driving her everyday, 13 miles each way to work. Getting a little heat soak after about 15 minutes when I'd run into the grocery store, but nothing I couldn't live with.
Three days ago, I noticed she wasn't running at optimum. Seemed like a bit of a miss. Not so much at first startup in the morning, but as she warmed up, I noticed it when I'd pull up to a light. She ran great off idle, but AT idle in gear? Not so good. It progressively got worse; I was sure I had a fouled plug. I kept bumping up her idle screw just to keep her going because she was shaking at the stops. Never felt like she was going to die, and would take off great, but I knew something was wrong. Today was the first time I'd had to actually wrench on her, and I thought I'd share.
I checked everything I could think of. Pulled the plugs, they looked about as perfect as I'd ever seen. Checked for vacuum leaks. Nope. Checked timing (maybe I didn't have the lockdown tight enough?) Nope. Checked fuel filter. Nope. Pulled the dizzy cap. All was good in there. I couldn't figure it out, but I felt it was in the idle circuit, because she ran so well at RPM.
Decided to try the whole 'I'll run the RPM up while choking her with my hand, and see if maybe I can unplug something' routine that my dad showed me so many years ago. THAT made a bit of difference. Not a ton, but I gained a hundred RPM at idle.
I was just staring at her while she idled, and saw a can of Seafoam I had in my toolbox. I've been running a can every two tanks or so because she sat so long. Anyway, I poured about half the can down her gullet, while keeping her running. Didn't seem to make a big difference, so I flooded her out with a good portion of what was left, and let her sit for a bit while I replaced my temperature sending unit out.
Long story short, when I fired her back up, I expected a bunch of smoke (I'd been down this road before lol), but what I didn't expect was for her to be idling at 1100 RPM, and just PURRING!!!
No misses, no stumbles, NADA! I brought the idle down to 700 or so, and man, she sounds and drives great!!! Decided to reward her with a bath and a cruise down the country roads around town. Damn fine time.
Here's the question:
WHY did it fix it? I mean, she's idling better than she EVER has. Granted, I've only been messing with her about 5 weeks after sitting for several years, but still. She idles as smooth as my 2019 DD.
Was there simply a blockage in the idle circuit? Could the 'top end cleaning' thing be real?
Anyway, I'd love to hear y'alls thoughts, and thanks for reading!
Gotta run to town for some cold snacks. Yep, I'll be taking the long way. ;)
Catbox
Peter
C20 Silverado Camper Special
Definitely a VGG fan.
I suspect there may have been some buildup on the valves where they seal to the seat that may have been cleaned off from the Seafoam.
Supporting Member Army
That would be my guess too. You probably had a rough idle due to a compression leakage from a leaky valve. Good heatsoak with the seafoam probably cleaned off whatever was stuck to the valve seat or maybe seat a piston ring. My truck had always had a miss and ran rough with a difficult time idling low. It wasn't until it blew up that I found the cylinder that had always had low compression and misfire issues had both compression rings broken into 20 pieces or so.
78C10BigTen
pennsylvannia
C10 BIG TEN
This title immediately made me laugh! My dad used do this in his 73 c10 while cruisin down the road... hed look at me, reach down and grab the choke and say its time for the "buck fifty" tune up lol
Old60Driver
1983 K20 Silverado
Houston
Michael
K20 Silverado
Holy hell!! BUCK FIFTY TUNE UP!!! Awesome!! Totally stealin' this! :cheers:
Old60Driver
1983 K20 Silverado
Houston
Michael
K20 Silverado
Roger that. I was kinda thinking the same thing, but needed some backup! lol
I've done quite a few Seafoam heatsoaks, but never had results like this. Ain't complain' though.
Hitting the road for a 10 hour road trip tomorrow at 0200. Wish me luck!
rpcraft
Robert
LS 6.0 364 CID
Sitting is the worst thing that can happen to older vehicles. Crap in the fuel, lines, filters, etc etc, just makes it's way into the carb and elsewhere. Ethanol makes things worse. If you do not run a motor that has had older types of oils in it and was perhaps not changed often then it is easy for the sludge to stick to the valves, valve faces, piston faces, etc etc and as the engine cools it turns into tar and eventually hardens and makes stuff stick or wipes bearings and rollers. The italian tune-up helps because the idea is you are going out and warming the motor up and then providing it runs well enough you are running the engine at it's max peak efficiency, which means making power. It blows out the crap to some degree.
Camar068
Air Force Supporting Member
10 yrs Air Force
love seeing seafoam fixes.....I just love the stuff. Of topic but I thought my weedeater was gonna blow up it was idling so high after 2 cap fulls in the tank lol. Just one example.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
My Dad always said he needed to "Blow the carbon out ".
:p
Same idea - some excuse to flog it.
:D
rpcraft
Robert
LS 6.0 364 CID
Seafoam isn't good for cleaning carbs or trash out of gas tanks. You know what is? Actually taking the stuff apart and physically cleaning them. I see guys on bikes all the time talk about use some seafoam, then weeks later they'll post again talking about how their bike still runs like crap.
Duh....
At best seafoam is decent for cleaning some parts in the valve train and top of the piston because of the steaming action, but then again so is water if you know what to do and how to apply through the carb, otherwise get some fuel injection cleaner and follow the steps for FI setups.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
:p
:D
Haha I have that same memory. Blowing the carbon out. Great excuse to drop the hammer. It's a tradition I'd like to keep alive.:burnout:
Octane
Atlanta
Eddie
Duh....
And it's amazing what a two day carb soak can do in a gallon can of carb parts cleaner.And also the compressed air.Just rebuilt my 44 year old carb for the first time since it was new.That dirty idle circuit can be a problem.
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
Seafoam=an apple a day keeps the doctor away.
Carb'ed Vortec 350
Duh....
Motor Purr works, though. I use it in my chain saw, lawn mower, vehicles. Chain saw won't start. Add some motor purr to the fuel, let it sit for a day, go to start it and it will start. Lawn mower sits with gas in the tank, add some motor purr to the tank before the first start of the season, and one pull, it starts. No issues with anything gummed-up. Old Tecumseh-power rototiller from Western Auto, that dates it to at least the 60s or 70s, and same thing, motor purr de-gums the fuel system very effectively. Of course finding motor purr is the biggest challenge.
Scrambler-Cafe
