I need HELP!! Lights switch and ignition??
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Just got home, I tried to start and it doesn't, but all the lights are now working...so is the new switch...go figure... I have no idea about what the problem
Is....
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
It just started...I noticed that the gas tank switch was "in between". I probably hit it while working in the light switch yesterday... I still have to figure out what's the problem with the lights...
350runner
tx
Ceasar
Fuse link...
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
THIS IS DRIVING ME CRAZY!! The new switch was connected hanging from the wires under the dash, so I pulled the knob out, mounted the switch on the dash and...same problem again...no lights and the engine cranks but doesn't start...
350runner
tx
Ceasar
How many clicks does it take b4 the engine will shut off one or two?
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
The switch is not working, no lights. And the engine is cranking but doesn't start.
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
At the moment the position of the switch doesn't matter at all, It is like there is no spark
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
It is like the light circuit is acting out and when it does, there are no lights and the engine cranks but doesn't fire up
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Do you know what this is??
350runner
tx
Ceasar
To narrow it down as to what lights are causing this is why I asked...
dot4x4
Cottonwood CA
scott
c10 Silverado
The no lights and the engine cranking is EXACTLY what mine did. I would check that fusible link and all connections at the starter. It seems strange but all the light power comes off of the starter lead and one of those fuse links.
I drove mine for a few days without lights until the wiring on the starter (Or the starter itself) fried.
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Yes, i know...
This is pretty bad... I raised the carpet and there are some lose wires, and everything is wet...
dot4x4
Cottonwood CA
scott
c10 Silverado
Ouch.... That wire nut is made for house wiring not auto electric. That could be part of the problem. With it exposed and wet your going to ground out in all the wrong places.
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Feeling depressed....
paolotvl
Cypress, TX
Paolo
V10 - Custom Deluxe
Where is the fuse link you mentioned?
crowe-t
