I need help diagnosing 1987 chevy
sqaurebody
Florida
Riley
R20
350 sbc
I have a 1987 r20 and it has started stalling out while driving just fully losing all gas it seems like but still has power. Any help diagnosing that is appreciated
AZ Highlander
Prescott AZ
Frank
K15 (aka V1500)
350 (5.7L)
Its gotta be a lack of fuel, air, or spark.
Is it the 87 original throttle body injection or carbureted?
Does it happen at a particular time/situation?
Has anything been fixed/done lately before this started happening?
Scott91370
Burleson, Tx
Scott
Sierra1500
You're definately going to have to be more specific.
Does it happen under accelleration, at constant throttle, when letting off throttle or any time?
Have you check the fuel filter?
I'm confused by 'it still has power'. Do you mean electrical power?
mtbadbob
Montana
Bob
V20
Start by replacing fuel filter on passenger side frame rail under the front of the bed.
sqaurebody
Florida
Riley
R20
350 sbc
Tbi it usually happens when I'm go9ng around 50 but it happened for the first time when I put it in reverse and went to back up, no I don't think I messed anything up
sqaurebody
Florida
Riley
R20
350 sbc
Happens usually under acceleration and yes sir still has electrical power constantly thru the whole process of just completing dieing
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Sounds kinda like symptoms of bad distributor components. When it dies does it usually restart? Does it happen more often when it's warm? Does it loose injector pulse?
sqaurebody
Florida
Riley
R20
350 sbc
I haven't checked the injector pulse but it will start right back up immediately after about 2 minutes
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
Fuel pickup sock? What did the filters that you replaced look like?
squaredeal91
Greg bush
1991 SB
I just replaced both of them, it seemed like the injector were spraying good
I'm sorry meant to say check pulse while cranking to know if its losing spark and dying or losing fuel and dying. I understand the injectors are new. But there told when electronically. Sometimes the pulse will fade because of a bad pickup coil and give these symptoms.
Dale A
Bremerton Wa
Dale
R 3500
I had a similar a problem that turn into not even starting. The map sensor was bad. I would also check or replace other sensors in and around the TBI and engine, such as the TPS, Throttle Position Sensor. Maybe even the heat sensor in the block that fed the ECM.
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
Try gunning the gas from a dead stop if it shuts off it’s ignition module (sits on dizzy two screws)
Johns C10 Hubcap
