I need help buying my tools for class at school
davbell22602
Bunker Hill, WV
I Dont
Have
One
There aren't too many T65 fasteners out there. Some Subarus, I think.
You might have to pick that one up separate...But I really wouldn't worry about it. You might run across one once every a year...
So a T65 does exist then? Another forum site said it jumps from T60 to T70 and T65 doesnt exist.
towman
harrisburg pa
jay
v10
can honestly say i have never had the need for 3 eights drive inch socket, as far as metric i use the 18 and 19 all the time on caliper brackets, but have never needed a 20 in 2 eights, i think the torx 65 fits the caliper brackets on the luminas and such, the one i have only came in half inch drive
towman
harrisburg pa
jay
v10
ok that is the biggest torx i own than, never had a need for anything bigger
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
As I said, T65s are rare but they are out there, some GMs use them, notably the 4L80 oil filter.
davbell22602
Bunker Hill, WV
I Dont
Have
One
The T70 is used some gm and a drain plug on a subaru. The T65 doesnt exist on ebay but the T70 does.
RetroC10Sport
Jay
pontiac aztek
You won't be needing one, really. I'd stick with a T60 being your biggest. If you should happen to go to work at a Subaru dealer, they will usually provide one.
bobcooter
Arnaudville, La
Robert
C-20 Scottsdale
As far as end wrenches go. I've had good luck with Proto.
RetroC10Sport
Jay
pontiac aztek
davbell22602
Bunker Hill, WV
I Dont
Have
One
I'll probably go with craftsman on wrenches cause they come in sets. Snapon just sells them individually.
davbell22602
Bunker Hill, WV
I Dont
Have
One
Snappy sells sets. Are you going with regular or ratcheting?
I couldnt find a set that had 1/4 to 1in in open end or box end or equilvant to that in metric. Sears has 1/4 to 1 1/2 and 6 to 32 in metric in box end for $179.99. Sears open set is 1/4 to 1 5/8 and metric 6 to 32 for 143.99. Just regular for now. Will go ratcheting before the school year ends.
RetroC10Sport
Jay
pontiac aztek
Well, remember you won't need most of those sizes. You will rarely use anything bigger than 24mm, or 1 inch when working on most cars.
redrosec10
