I need a detailed ECM pinout diagram
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have been searching for a intermittent misfire on my 92 Yukon. Occasionally, the #1 injector (the on on the passenger side) won’t pulse. No injector pulse, swapping injector plugs and the problem follows the connector.
Make a long story short, the dark blue wire (#1 ground) terminal was push out the back of the ECM connector. No connection, no ground, no injector pulse. Now, my problem:where did that wire go?!
I found a diagram online, it said dark blue injector ground goes in connector C, pin 16. Only problem, that cavity is already occupied. So obviously the diagram I have is incorrect.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
So, does anyone have any clue where the dark blue wire is suppose to go??
yevgenievich
Viktor
sad
very sad
less sad
Does it ohm out to the injector connector? Confused how the problem was intermittent if that pin was fully out
yevgenievich
Viktor
sad
very sad
less sad
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The pin was just barely in the ecm connector. It came out when I unplugged it, unfortunately I didn’t get a good look where it came from to reinstall.
That’s definitely the same dark blue wire to the #1 injector, as verified by a continuity test.
yevgenievich
Viktor
sad
very sad
less sad
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
That’s it!! The illustration I found online said C-16, your illustration says D16. D15 is blank (as is in my connector) and cavity D14 is green, ground trigger for injector 2 (and I have a dark green wire in cavity 14)
Only problem, the terminal refuses to go in all the way.
Camar068
10 yrs Air Force
not knowing the connector at all, but you may need to clock the pin in the hole. Look at the other wires going in and put it in the same way.
just a thought.
yevgenievich
Viktor
sad
very sad
less sad
There is specific orientation to terminals. Otherwise cavity might be damaged
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I’m guessing the cavity is damaged, the terminal flat out refuses to go in. It will go in other cavities ok.
I’m guessing that particular terminal has been screwed up since day one. This truck ran flawlessly up until a few months ago when it occasionally would shake and barely run. The miss has slowly degraded and become more frequent. A few months ago, my son and I replaced a blower motor that howled pretty badly. I’m thinking that fooling around with the blower motor compromised a less than ideal connection that has degraded over the last few months.
yevgenievich
Viktor
sad
very sad
less sad
Either try to straighten the slot with a pick. Or open ecm and put a jumper to near by pin that is empty and use that cavity
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I have friend with a bunch of these trucks, I’m going to see if he has another ecm connector. If so, I’ll either splice the connector or repin the replacement. Thanks!!
Camar068
10 yrs Air Force
d@nm good thinkin' there
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
It’s fixed. I got a replacement terminal from my local GM dealership (cost a $1.04) and cleaned the cavity with a pipe cleaner. Terminal snap in place, spliced the wire together, runs like a champ again.
Wish all repairs were that cheap.
87POPS
