MadOgre
- May 4, 2014
- NA
- NA
- NA
- NA
- NA
Spent a good part of the day moving the accessories and whatnot over to the new engine. Called a guy who does a lot of engine work and he said I need to buy an aftermarket TV cable bracket that bolts under the stock q-jet carb.
And as far as the coolant sensor thing- I removed the 1/2" NPT fitting on my intake manifold and could NOT screw in my stock coolant temp sensor. The way they machined the intake manifold there isn't room for the probe part to protrude inside the manifold. Looks like I'll just try to buy an aftermarket gauge locally. I didn't want to do that- but it will be more accurate than the factory gauge. Since I don't have AC I'm thinking of mounting the gauge in the little cubby hole the dash has on the upper right. A 2-1/16" gauge will fit nicely there I think.
My last possible surprise I found today is the GM high flow fuel pump. That thing is so big the case of it hits my motor mount. It is way bigger than the stock pump. The lower 1/2 of it you can clock it around so that the inlet and outlets can point a different direction (they are 180* out from each other). I was hoping to bolt it on with the engine out, but since there is clearance issues looks like I'll fiddle with it when the engine is installed. That "should" happen tomorrow.
You must be registered for see images[/IMG]
So whats wrong with your current TV cable? After market is really no different from stock. What you will need is a Throttle/TV cable bracket. TCI has a good one for qaudjets. I like it because it bolts to the carb so it works no matter what height you manifold is.
Part # 376700
What is the purpose of that monster fuel pump? You can only use so much fuel at one time you know. I would send it back and go with a stock one or an electric unit with a regulator.
