how to the remove the tank selector switch from the dashboard
roadwolf
France
Rodolphe
silverado 10
I've fueling issue with my 5.0 1987 tbi, i want to renew some of the parts, i already have 2 new tanks, 2 new sending unit/fuel pump (not installed yet), a new fuel filter, i'll change the fuel pump relay and the fuel selector switch on the bottom on the dashboard.
I was running on only one tanks since 3 years (right one removed) but now sometimes my fuel gauge goes crazy, and the truck stall and will not restart for a moment.
I was wondering how to get it out from the dash, what should i remove before i can access to it.
the tank selector valve seems to have replaced, i've the bill from the previous owner, but i think the mechanic who did the job wasn't honnest as on this bill there is also a windshell pump which i had to replace 6 months later and found a totaly old rusted part in place.
thanks
1low4x4
Nick
Small c clip on the back of the dash holding it in... Then it just unplugs from the harness
roadwolf
France
Rodolphe
silverado 10
I am sorry, but i can't see how i can access the clips behind the dash, there is a sidewall on the right by the ashtray.
and an air duct [probably AC] at the bottom
i can't put a hand behind to release any clip.
1low4x4
Nick
Got.to take the bottom air duct out. Can be a bear
roadwolf
France
Rodolphe
silverado 10
And i think to remove the air duct, i need to remove the gauge cluster bezel.
well that' s not a five minute switch swap, i have to take my time.
Thx for your help
jetman
Minnie, AK
Don
Air Duct will come out without removing the gauge cluster bezel. Just grab hold of the Air Duct and pull, it comes out easily, may have one bracket/nut holding it in place.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
My selector switch, just popped out. I gently pryed both end with a flat head screwdriver. The replacement switch snapped back into place ...no metal retaining clip on mine. If you're replacing the switch with a new unit, looking at the new unit should determine how to remove the old unit.
roadwolf
France
Rodolphe
silverado 10
thanks guys,
i manage to remove the tank switch, the air duct came by removing screws of the metal panel under the dash board.
SquareInheretance
