Help With Installing Grille Emblem
moorevisual
Atlanta
i bought an aftermarket stock grille and a used OEM emblem, but i can't figure out how these work together...am i missing a piece or something?
gmachinz
Harnessworx Inc
Iowa
Jabin
Aftermarket grills do not have provisions for a stock bow tie.
moorevisual
Atlanta
dang it i didn't realize that o well i guess i'll try to fab something. anyone had any luck going that route?
MrFiveOh
tx
Andrew
You will need a factory grill to use that emblem. It looks like the emblem that was on a 67-72 C10.
you will need a 73-79 factory grill like this. https://www.google.com/url?sa=i&rct...qNScvLl-3RP6GNBv68vumyuw&ust=1475872138272635
I used the 67-72 emblem on my grill like you are trying to do.
moorevisual
Atlanta
It's the correct grille and emblem, year-wise (1979), I just didn't realize i couldn't use the emblem with the aftermarket grille. I've got a couple ideas on how to make it work though
Love that blue bowtie btw
MrFiveOh
tx
Andrew
Thanks, its hard to see your grill behind your hand. there is supposed to be an outline for the bowtie where you would mount it, Originally a foil sticker was in place of where mine is now. Apparently aftermarket doesn't come that way from what i t looks like.
MrFiveOh
tx
Andrew
moorevisual
Atlanta
i cobbled something together that will be good enough for now
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Looks great! Is this a company secret, or would you be interested in divulging your methods?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I was gonna suggest using longer threaded studs and expansion anchors used in drywall.
moorevisual
Atlanta
lol i should have taken a pic before i installed it, but all i did was cut to length a piece of flat 1" aluminum i had laying around, drilled two holes in it so i could mount the emblem to it. then i was able to use 4 zip ties, two on each side of the vertical and horizontal grille parts, to center it and hold it tight. it's on there pretty good.
smoothandlow84
Steve
Ahhh yes...zipties. I always have a large assortment of them in my toolbox along with duct tape and stainless steel safety lock wire.
Obullard74
