Help with back glass install.
I'm buddies with a glass guy, I just butter him up with spare parts or give him 10 bucks to buy some beer.
Sorry, I'm no help.
A simple "I don't know" woulda sufficed but.... :slap:
:roflbow::roflbow::roflbow::roflbow::roflbow:
oneluckypops
Sedalia, Mo.
Luke
YEAH!!! where's the write up? where's the write up? where's the write up??
well good lord, hell i just got done rebuilding a 700r4 that was in pieces that someone couldnt figure out how to do. I guess I might try to tackle the back glass tommorow. I suppose i will try to take some pictures for all you slackers :roflbow:
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
get the rope wet(i use windex easy clean up) put it around the rubber lip with the tails on the inside. i put the tails on the top in the middle. have someone hold the window in place with light pressure then pull the rope to work the rubber lip in place. might need to help get it started with a screw driver but then it should pull right in.
you can usally set the bottom corners in place pretty easy to start
keep the rope and rubber wet as you pull
Ah man, you'd think with a statement talking about wet, rubbers, lips, tails, rope, pull right it, and pretty easy etc etc that it would be an interesting convo. :shrug:
But yeah, that's pretty much the best explanation so far. Now, I've never used the wet rope trick, but I do remember one being a real bitch before, and it seemed I used vaseline on the rope and inside the seal to try and get the seal more flexible and pliable. Leaving the gasket laying in the direct sun for 15-20 minutes at first might help too.
1tonman
Ga.
matt
c30
Ok fellers I am hoping someone here can help me get this back glas switched around. I have a cr lawence dark tint that was in my 79 before it got crushed. I would like to install it in my 85. I had planned on taking it to the glass shop and just leting them do it but they seem to want to charge as much to use MY glass as they do if I was to have them order one. can someone help me out maybe with some pictures?
hey man, dont have any pics, but of you take a griter string, and saw it around the glass, you can cut the old rubber out, and then pull the glass out, and put back with new rubber. but it helps to have someone inside, to help hode the glass
Some baby oil to go along with what he said or soap would go a lot easier also. You defenitely need two for this job
Easy there. You get his wife in the truck to hold the glass, and some baby oil in the cab, they'd have to run the kids off and get arrested for indecent exposure, lewd acts in public and a host of other charges.
Peanut oil is made from peanuts, vegetable oil is made from vegetables, etc.
What is baby oil made from?
Dennis Blom
