Help with 700r4
Jared Albanese
Fremont ca l
Jared
Just bought a 86c10 305 700r4 combo. Tranny will engage in all forward and reverse gears, but will not move unless revved super high there is a loose part that is on drivers sode that goes into transmission. Will tighten it tomorrow and see if that does anything. I was thinking maybe torque converter. Either way i guess im on hunt for a cheap used 700 while i pull the #s matchimg one out to be rebuilt. Any help or opinions would be appreciated
yevgenievich
Viktor
sad
very sad
less sad
Sounds like a slipping trans. Check fluid level and see if it smells burned. Also double check if tv cable is hooked up
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
How many threads are you gonna start on this?
You mentioned in the other one something about a concussion...u feeling alright?
Kim Burke
Northern IN
Kim
C1500
Save the engine, don’t rev it too high, and ditto on checking the fluid. Should not be dark and/or smelly.
If TV cable isn’t connected or mis adjusted, your tranny is toast.
87R10_Cruising
