idahovette
- Aug 7, 2016
- Weiser Idaho
- Perry
- K20-K10
Balancers can't be changed???
I don’t know **** from shinola...
But that damper looks as big as the one on my 350–which is an 8”
Gotcha. This only validates my statement pertaining to shinola.The thickness, not the diameter, that and the spark plug wire holders on the back of the block. Of course, those could just be sourced from an old block and ram horns used, but this one has headers. Without a top view or some other information it could be anything, but I will side with @highdesertrange on this being a 283 or 327.
Yeah ,I knew that. Was trying to be sarcastic. I'm not as good as Honky. Also the small plug in the oil galley at the front of the block above the timing cover says pre 350Pretty sure that all SBC balancers were interchangeable, except the 400.
............Also the small plug in the oil galley at the front of the block above the timing cover says pre 350
I'd forgot about the "**** and shinola" phrase, thanks for the blast from the past.
