help identifying a 700r4 and how to swap in place of T400
1low4x4
Nick
2 purposes of this thread. Now that I have my truck back id like to swap in a 700r4 in place of the 400. I just really want that overdrive and I figure I can pull that boat in 3rd. Overdrive would be nice for every other time. I know it has 4.10s but thats another story.
I read the thread on how to identify a 700r and looking at this one I aquired I see it has no rainbow, no serial number cause its been grinded off, but it does have the pressure taps which I think indicate an early 89 or pre 89 right? It has a sticker saying pretty much its a rebuilt gm trans and it does have a serial number on the other side on a plate. Ill post the pics up and maybe yall can help. I plan on bringing it to our trusted trans place and having them go thru it for me this week.
Second, what all do I need to change to fit this trans in my c20? I havent had time to get under there yet. Will the driveshaft need to be shortened or lengthened? Speedo and kick down cable work? What about the little 4 prong square female plug on it?
Any tips would be awesome. Thanks!
1low4x4
Nick
Ok from what ive read ill need to move the trans crossmember back but i can use the same one. Also I need to shorten the driveshaft? Ill be taking the trans by the shop today
1low4x4
Nick
Crickets crickets....
Dropped the 700r4 off today, guy is supposed to go thru it and contact me on what it needs. Hes a pretty reputable shop.
Someone told me I may need to actually lengthen the driveshaft not shorten. Any takers on what all needs to be done here?
MrMarty51
Eastern Montana
Martin
:chair: wake up,there`s a :party33: going on out here. :popcorn:
Driver4r
Nebraska
Trevor
k10,c20
What are the output nose/cone lengths? the 700r4 and the th400
IROCmenace
TN
C2500
350 VIN M
What did you end up doing on the 700 swap? I have one sitting around and the 3 speed 400 with 4:10's is killing me.
87lsxgmc
buffalo
im doing a 4l60e swap in my truck now. im having a heck of a time finding a driveshaft the right length. i found a one piece at a bone yard, but its still about 4 inches short, most likely going to find someone to cut lengthen, and balance it and run that one. if you have a 2 piece shaft, youl need just the front section for either a 700r4. being down south im sure you can find one in a bone yard. for me up north not so easy to come by. good luck.
1low4x4
Nick
Sorry guys, I ended up doing a 4L80e swap.
flynhigh88
