Hello from upstate NY.
JGV66
New york
Joe
Hello everyone, I'm new to the forum.
I have an 86 k10 Scottsdale short bed. I'm the original owner and am in the process of restoring it. It is in the restoration shop and I'm looking for some advice on some parts.
The truck has 9'' of lift i just replaced all the old rancho lift kit with new 6'' skyjacker easy ride springs. it also has a 3'' body lift, a worked over 350, and 3/4 ton axles, i installed ORD. shackles with greaseable pins and Kevlar bushings.
The headers need replacing they are from the 80's
Here is the first question does anyone know of headers that will clear the front shackles on the passenger side front spring. the new ORD shackles are much thicker than the stock ones and the bolts hit the header where the exhaust pipe and header flange connect. i had to grind down the old flange on the old headers to make clearance but would prefer to not do that on a new set of headers. and i would prefer long tube.
Thank you.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
animal
Moderator
Lee
c10 silverado
350ish
:welcome:
Marine Corps Moderator
:welcome:
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Pics please.
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
That's cool. Original owner too! Sweet truck. Oh yeah, welcome from Texas, DFW.
Strick
Dunn, NC
Harold
C20 Crew
Welcome from NC. That’s a flashback to the 80's there! I like it!
HS
86 C10 Shortbed
Ohio
Mark
5.3L
Welcome from Central Ohio.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Thank you.
My hedmans clear the ORD shackles just fine. Did have some issues with frame clearance, but not sure if that may be specific to the taller 1-ton frame or not. I got clearance by a few hammer blows to the primary tube and a tiny bit of frame grinding.
hack_man
MA
Tony
Welcome @JGV66
How is upstate NY as far as being picky on emissions for an older truck from the 80's? If there are some mods with say a missing smog pump is that an issue?
JGV66
New york
Joe
Welcome @JGV66
As of now they don't check for pollution /emissions control on vehicles 25 years and older so right now you can run a 1999 with no emissions.
