HEI Modules
Terlingueno
Fictional Western Sage
Far West Texas
Skeeter
K20 Suburban
350/SM465
Found this listing on "that auction site". They are the 4 pin like my K20 has. The box is Delco like and says Made in USA and Fits Delco D-1906 1875990. Anyone have thoughts on these?
Sad Sack
Nebraska
Goober
C15
I always thought Delco put part numbers on them...I could be wrong.
The guys that have ignition module problems are usually the guys running low or mid grade parts store modules. The guys that don't have module problems are the guys that are running genuine gm modules. To the best of my knowledge genuine GM ( delco gold) and NAPA premium are the only modules that vary dwell.
WFO
Texas Panhandle
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
The Delco 990 modules are considered the “performance” module. I have no clue what makes them special. It’s mention on the Buick, Pontiac and Chevelle forums.
Terlingueno
Far West Texas
Skeeter
K20 Suburban
350/SM465
Yeah, I have two like this, one lives in the glove box. I got them from the little mechanic shop that installed my crate motor, in the industrial part of Las Vegas. Looking for a couple three more just like them thus the haunting of "that auction site", just in case...
MikeB
Have to ask why so many spares? I must be very lucky. Because in over 40 years and around 8-10 cars and trucks, including some 70s and 80s daily drivers, I've never had a module fail.
I bought the spare module just to have one in case GM stops making them. And they're not getting any cheaper. Are these real GM modules that are failing? And you are using thermal paste to transfer heat to the HEI plate?
Not picking on you, because I hear the same thing on other forums.
Terlingueno
Far West Texas
Skeeter
K20 Suburban
350/SM465
Well I have had only one car, this one, since 1994. It is pushing 450K miles on the ODO. I have had two failures. One in 2006, in Death Valley in 120+ degree temps. I had my hood up, no cell coverage, of the five cars that passed by me in three hours, one stopped and gave me a ride to my quarters and got a coworker to tow me back. By that point, I had owned the truck 12 years by then and I think the module was the original. Fast forward 10 years and I had another module fail here. In 115 temps. Fortunately I had cell coverage and got a friend to tow me the 3 miles to my quarters. Since 2006, kept a spare in the glovebox so I could fix it on the side of the road. To answer your question, I want a cushion for the future. Just in case GM stops making them...
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Same here, I have had a few modules that would die when the engine got really hot, then restart when cold. But I have only had one outright fail.
The early HEI modules did have some issues. DELCO quickly figured out the issue. But the reputation remains.
Get a good DELCO or quality aftermarket module and install it with thermal paste, and they last.
ali_c20
Austria
Alexander
C20, K5
I run a DUI distributor and the module works as it should since 2014.
I changed 1 module long time ago (el cheapo from PO to ACDelco) and I used good thermal paste. I gave this distributor to a friend and it still works.
Don't cheap out on them and install with thermal paste. My 0.02$
gmbellew
Kansas city
glen
suburban 1500
Modules are one of the few things that will leave you dead in the water, take up almost no space to keep a spare, and can be changed with just a screwdriver in a short amount of time. It just makes sense to keep one, like it makes sense to keep some fuses, spare fluids, etc. and I 100% agree…use an AC Delco module and it should last a long time and you probably will never need the spare. But the cost of preparation is low.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Surprise!! I ordered 2 and they just arrived. They definitely look like there as old as the boxes are. They look like a gm module in lots of ways but they don't say anything. They are heavy and im sure good quality being as old as they are. Either way not a bad deal.
Its just interesting that they don't say anything on them and that the box says fits Delco D-19061875990 and the box is blank otherwise, has the Delco symbol but doesn't actually say delco . Maybe they Are an oem economy line?
Terlingueno
Far West Texas
Skeeter
K20 Suburban
350/SM465
Like I said in my original post, the box is "Delco Like" and the box pictured in the ebay listing has "Made In USA". There is another NOS D1906 on that site that appears to be a real Delco unit. Makes me wonder as to the origin of the original one I posted since it seems an effort to "Look Like" a Delco, and the same seller has some "remanufactured" units that look the same. So I dunno...
This is what looks to be a real one
Nborden88
