Heater Motor?
79c10paintedtwice
El dorado county
Barry
C10 stepside
79 C10 6 cylinder. Heater motor will not shut off when ignitionison. 3 speed switch works fine. Can not find another switch in the wiring diagram. Is there a switch actuated by the sliding controls?
ulm4lyf
Trevor
Sierra Grande 15
Mine is always on low. No other speed works. I've ordered a new 4 speed switch.
Tinker
LI, NY
Greg
C15
The system is designed to run at all times (when key is on).I believe it started in 74 or 75. As mentioned above a toggle switch could be wired in to stop that function.
79c10paintedtwice
El dorado county
Barry
C10 stepside
It's NEVER supposed to be completely off. That's what the 'flo-thru' ventilation system is.
Good to know. As others mentioned, a switch would solve the issue. It's a new motor, I'll let it run for a while.
WFO
Texas Panhandle
I put a brass ball valve on the heater hose of my 77, so it at least wouldn't be hot air in the Summer.
85K304SPD
Las Cruces, NM
Richard
We used to call it the summer heater, or something like that, "back in the day". It sucked to be the guy that had to ride in the middle. Oh well, we were Cruisin'. That is all that mattered.
I don't think that my '85 does that like the '80 that we were cruisin back then.
Turbo4whl
Downingtown, PA
Wayne
Yes, my 1974, no blower off. My 1982 has blower off. No AC in either truck.
79c10paintedtwice
El dorado county
Barry
C10 stepside
Thanks for the heater blower history lesson. It will now run forever. I did find a wiring diagram in my 1979 service manual. A lot easier to read than the reprinted diagrams I bought online. Unfortunately, first try with heater hoses connected, I'll be changing the heater core.
79c10paintedtwice
El dorado county
Barry
C10 stepside
Thanks. The local high-school auto class had painted it with school bus paint. I sanded to metal and primed with Eastwood roll on primer. Ended up spraying, too much roller stipple.
It used to be open wing windows were the "flow through ventilation".
yes but standard feature that even the competition has means thats not something you can put in a brochure to evoke feelings of features and advanced and on-top-of-it features like FLOW THROUGH VENTILATION. Vent windows being open? NOISY. FAN MOTOR BEING UNABLE TO TURN OFF AND HUMMING AND DRAWING POWER AT KEY ON? The. Future.*
*until they undid that choice in like 83 or whatever and called that a notable change
Dennis Blom
