Heat Riser/Stove pipe on an open air filter Help!
LilRobert1367
Colorado
Robert
I have an open air filter on My 79 C20, Since I live in colorado I want to connect the Heat Riser/ Stove Pipe to the open air filter. I was wondering if anyone has any idea on how I would do that? I have an idea of using a 1 1/2 in flexible exhaust pipe and maybe welding an exhaust flange to the the flexible exhaust pipe and putting a hole on the underside of air filter base plate so I would have a place on the air filter to connect the Heat Riser pipe/ stove pipe too!
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
You would be better off getting rid of the open style and finding a factory assembly, filters will be readily available and you won't be sucking in those hot under hood temps. I'm sure most here will agree with me.
Find one with the big 3 or 4 inch filter I think it's three. Then you'll have your heat riser hookup and better/more intake, and lower IAT's.
For what it's worth, I don't run my heat riser, and I live in ND and don't have issues. Just let the truck warm up and go, I have no driveablity issues after it gets warmed up. All of the farm trucks out here have long lost their heat riser tubes and are going strong.
Shak379
