Heat only on AC cab
Tranz Zam
MA
Ryan
LM7 5.3
So my new cab is was a factory air truck, but I want to go with heat only. I know the easiest way out would be to purchase one of those fiberglass AC delete panels, but I figured I'd try something else first.
I found an old thread on another forum, where the guy was able to bolt up his factory heat only box to the firewall. He had to cut a new hole in the firewall for the blower motor to be able to blow on the heater core, but other than that it seems like it worked flawlessly.
http://forum.73-87chevytrucks.com/smforum/index.php/topic,21690.15.html
Quick question, can I keep the factory AC components under the dash, or do you have to switch all that with the factory heat only setup? I skimmed through the thread quickly, and didn't find an answer. It looks like he kept the factory AC dash components, but idk?
Thanks guys!
74 Shortbed
I believe you have to change everything to heat only, heat only use cable controls and A/C uses vacuum, you'll have to make a plate to cover the A/C hole in the firewall too.
1973c10
Don
Hey there
They make a ac delete box or you can make your own
http://www.classicindustries.com/product/truck/parts/14446.html
when did mine I just took it all out and
rebuilt the firewall to a non AC firewall I made the new firewall it out of
18 gage steel sheet
Here is a before and after pics sorry there not that great
74 Shortbed
My truck was heat only and someone added the A/C, so now I have to make a plate to cover half the hole, shouldn't be noticeable when it's done though.
1973c10
Don
You will also need a inside and outside non AC heater box
and non ac heater control they come in 2 cable or 3 cable design
when I did my conversion I found a truck at the wrecking yard
and just grabbed everything it was like $100
Bacon
Maybe this will give you ideas. Heater only box with a hole cut and pipe welded. Was easy to set up
Tranz Zam
MA
Ryan
LM7 5.3
Interesting setups.
I think I might bite the bullet and buy the fiberglass delete panel.
I was running my cab harness today, and realized that the cab harness I have is for a non ac setup, but the cab is an ac cab. I assume I can remove the ac part of the harness and use the non ac wiring?
I'll figure it out either way I guess. I need heat!
mick84
