Headers or Manifold ?
81squared
Pawling NY
Marc
scottsdale
my truck came from the last guy with headers, they interfere with the auto shift linkage, I cannot shift into 2nd or 1st manually. It hits the header on the driver side.
i want to replace the headers with either the correct long tube ( preferred ) or use a hugger header.
I purchased factory manifolds but you cannot purchase the Y pipe after the manifolds anymore, one manifold has a donut flange and the other has a standard flange, seems this cannot be modified to accept new down pipes ( that is what I was told ) .
So Im thinking just buy headers that fit properly.
I dont want to spend more than 300 on the headers if possible. Ill coat them later
please any info would be appreciated
Thanks
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
^×2
It won't hurt to just beat a small dent in the hedder so the linkage won't rub. Your hedders look To be in good shape. I wouldn't buy new ones when you can make those work.
Rusty Nail
Rusty
350sbc
Actually...you'll do better to lay a deep socket or something on it and whack that. The cheater pipe for your rachet usually works pretty good..whack a trough that follows the spark plug wire - like a BOSS!
:waytogo:
SquareRoot
I had that problem. I just shitcanned the linkage altogether along with the trans. Dropped in a NV4500 and all is well.
81squared
Pawling NY
Marc
scottsdale
forget these things, sent them back they would be way to restricted with that stupid heat riser. Im running EFI shortly anyway.
IM sure the EFI will spark many questions
anyone recommend a good EFI forum ? SBC/Holley Sniper EFI
DrPrepper
Yucaipa,Ca.
Dwight
400ci
Were you afraid of the local muffler shop?
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Couple of options for you. Lokar (ACA-1800) makes this shifter linkage. Frankenchevy used it on his truck. You can get heat risers/bypass through Summit Racing in 2" or 2.5" if you want to run the OEM manifolds..
https://www.summitracing.com/parts/...MIiNm06bKk8gIVmB6tBh3ffgAZEAQYASABEgKGxvD_BwE
summitracing.com/search/part-type/exhaust-heat-risers/make/chevrolet/engine-size/5-7l-350/engine-family/chevy-small-block-gen-i
81squared
Pawling NY
Marc
scottsdale
thanks for the input , no wasnt afraid of the muffler shop lol, dont want restriction like that ...
Raider L
Shreveport, LA
William
@81squared,
I have the Lokar shift linkage kit on my truck but I'm running Hooker headers to. But the other guys are right, you take something like a large socket and find the place where you need room and you hit that spot. I'll guarantee you if you called Hooker they would tell you to hit it. As a matter of fact I saw recently a set of headers that had the dent already in the down tube where the shift linkage would be rubbing. It was already there! So hit it, Man, hit it!
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
@81squared,
There is a video on youtube on engine masters where they tested before and after a dent in headers. Because people dent em for spark plug access. After repeated attempts on the dyno it failed to make any difference.
Raider L
Shreveport, LA
William
@Jawzjeep,
Saw it. That's why I'm saying there is a brand of header, and I wish I could recall who it is, maybe Doug Thorley headers? I don't remember, nowadays there are so many header makers it could be any number of them. But they make them with a dent already in the offending tube. They know it's not going to make any difference on performance.
