Haynes manual suggest silicone dielectric grease for ignition module?
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
Here is my old ignition module . Do you guys think I should go with the silicone dielectric grease. Should I buy a better ignition module? Thanks
350 w/203
NO, NO, NO!!!
Like @gmbellew said; you need a thermal paste, sometimes referred to as 'heat sink grease'.
Get a genuine GM module. DO NOT get any generic modules from auto parts stores. You have been warned!
Camar068
Air Force Supporting Member
10 yrs Air Force
Anything getting hot expecting heat transfer to another material uses thermal paste. you can get a small can of it cheap on amazon....and that small can will last you a life time.
the processor on your phone or computer uses it to transfer heat away from it.
Where it's needed...a little goes a long way. Read up on it
Hugomartin
Banned
Nc
Hugo
So the Haynes is wrong?
Hugomartin
Banned
Nc
Hugo
Why not some type of washer to dissapate heat..... Fyi my ignition module is a duralast 'like oe' they said. It only lasted a year but free replacement
gmbellew
Kansas city
glen
suburban 1500
when you buy a new module, at least an AC Delco one, it comes with a little bit of thermal paste, not dielectric grease. I'd say the Hanes manual has an error. Thermal paste is what you should use.
Doppleganger
OH-MI: Just like it sounds
I've worked on and installed everything with electronic ignition that Bosch makes, and its ALWAYS the white thermal paste....and yes, things fail when its missing. Thats all I would use.
Memaloose
Bayard, New Mexico
Tony
I've always used "dielectric grease" it's never failed and I got it when I worked for the USCG. They used it on their Jayhawk helicopters, good enough for me.
Hugomartin
Banned
Nc
Hugo
Is this the proper paste?
fast 99
Spokane, Washington
Don't over think it. Either one will work. Always had dielectric in the tool box for other uses. Have used it for 30 years, it works. So may thermal paste, didn't have a reason to stock it.
A GM module would be preferred.
Albrigap
South Dakota
Alan
Suburban
No, this product protects something from heat. It is the opposite of what is needed. You need a product that easily allows heat to move through it. I use the stuff used in the computer world. Mine is Arctic Silver, high density polysynthetic silver thermal compound. The module generates heat. The heat must transfer from the module to the distributor to make sure the electronics don't burn out within the module. Those are not real fun to change so do it right the first time. That way you are not out in the middle of nowhere broke down.
Scrambler-Cafe
