Hat sections for bed attachment
SideStepT2020
Victoria BC
1980s?
C-10
I need the hat sections that are used to attach the wooden bed to the frame. Its an 81 frame but the bed/box are from a 70s stepside. has anyone ever made there own? I have access to a full sheet metal shop. I have looked online and there was nothing in stock anywhere and i figure they may need to be custom anyways.
Dave M
Banned
Australia
Dave
Is that them, the cross sills?
SideStepT2020
Victoria BC
1980s?
C-10
I believe so! I am not sure if the will match up with my frame though. Any idea if the standard shortbox frame and the stepside frame are the same?
Dave M
Banned
Australia
Dave
They mention they're for '73 to'87 so l assume if your bed and frame are both within this period, then they would fit. Perhaps someone else will jump in with the answer for you.
fast68chevy
I am the original fast68chevy
LINCOLN IL
RANDY
frames the main dimenions/widths etc are all same 73-87/91 and step box is same 1947 to 1987. the fender tubs changed, but not the main actual box. for 40 years.
SideStepT2020
Victoria BC
1980s?
C-10
Does anyone have some cross sills that they could provide some measurements from?
I can make the hat section on the break if I have the dimensions.
DanMcG
Central NY
k10 k10
I could measure one up for ya,
DanMcG
Central NY
k10 k10
That would be great!
just added to the post above, I'll check the material thickness in a minute
I measure anywhere between 0.093- 0.098 ...its got some surface rust so maybe it 13 gage (0.090) but might be easier to get 12 gage (0.105)
SideStepT2020
Victoria BC
1980s?
C-10
Thats great! Thanks for the measurements!
Could you also give me the overall length?
DanMcG
Central NY
k10 k10
49 7/16" overall.
If there's anything else ya need just let me know.
DanMcG
Central NY
k10 k10
I forgot to mention there's a 14 gage (0.075) plate where the rail contacts the frame. I'm thinking it's mainly to prevent the hat channel from splaying out.
  • Like
Reactions: WFO
SideStepT2020
Victoria BC
1980s?
C-10
Awesome! Thanks Dan! I will post some pictures when they are finished
Sprockmonster
Connecticut
Logan
I realize this is an old thread but a few of the supports I scrounged up for my bed rebuild had a piece of rolled sheet metal as a spacer tacked inside the channel to support it. Without them I foresee the support buckling when torqued down.
I cut and tacked in some black pipe to replace the ones that were missing.
Mavric16
