Harmonic Balancer Install help-- SBC
84 c10 o skool
Houston, Tex
Steven
383 stroker
Hey guys.. I install my ATI harmonic balancer on my sbc. I also installed a
different timing chain cover. So when I went to install the timing tab I could
not see the timing marks on the balancer.
Did I do something wrong? I installed the balancer with the installer kit.
Or do I need to purchase a timing tab from the same maker as the timing
chain cover??
thanks.
firebane
Calgary, AB
Curtis
You need to find TDC and match the timing tab to the balancer.
84 c10 o skool
Houston, Tex
Steven
383 stroker
the tab covers the entire width of the balancer..
84 c10 o skool
Houston, Tex
Steven
383 stroker
the balancer went on with no problem. When it bottomed out it stop and so did I.
84 c10 o skool
Houston, Tex
Steven
383 stroker
Bought the timing pointer for my ati 6.235 damper.
Right fit and looks good, it should for paying $40.00 for it.
Will post pics..
84 c10 o skool
Houston, Tex
Steven
383 stroker
here is the new timing tab Mildolon tab for 6.325 ATI Damper.
I called about the clearance and the rep told me that it is suppose to be a really close tolerance. Damper moves freely and does not hit the timing tab.
blue tap is when I was finding TDC and marking it.
MikeB
North Texas
Were you able to line up the pointer with the "0" mark at TDC?
What a shame you won't have a cheesy chrome timing tab to reflect the light back into your face. :)
That thing wouldn't have worked with a stock damper.
firebane
Calgary, AB
Curtis
LOL I installed that exact same pointer and it interfered with my power steering pump brackets.
84 c10 o skool
Houston, Tex
Steven
383 stroker
Yea.
TDC was right at 0 on the damper!
Don't know if I was lucky or everything is line up right and nothing moved on me.
Hope all goes on good and not have n e problems!
mikejeden
