86chevyc10
- May 1, 2015
- New Mexico
- Alejandro
- C10
hello gmsquarebody members. haven't been a member but a few days but already i like this forum better than some others i've been on. this is my first thread i'm posting. after quite a few threads i've searched through i could not find anything quite like my issue.
so to start from the beginning, i have 2WD 86 short bed with a 350ci from a 72 C10. been tinkering with it since 2006 but nothing major. Edelbrock 1405 600cfm with performer intake, long tubes, lunati voodoo cam, and TH400 tranny. last summer the rocker studs yanked out on me (blame the cam and pressed studs) so the truck sat through the winter until feb of this year when i purchased some ProMaxx 185cc heads. installed them shortly after also installing new rods and jets since the new plugs were jet black when i pulled them (after a few trips around the block). also installed new NGK plugs, taylor 8MM wires, holley fuel pressure regulator, stock spec oil pan (last one dented from previous owner) as well. fast forward, i went to go register it the other day and cranked for a while but no start. i sprayed some throttle cleaner down the carb and got it going but it had a rough idle. in Drive it would push forward as if i kept giving it gas. took if for a spin and it shut off on me down the street while doing 20mph. turned the key, gave it gas and it started again but i turned it around. shut off on me again then it would crank fine for a few seconds then sound like binding with a clicking noise only during the binding sound.
the following i've checked so far: checked timing and firing order repeatedly even though it ran fine quite a few times before. checked all vacuum lines. checked put in old rods, same effect. had wife crank while i checked around engine bay and underneath, thought i felt the clicking with my hand on the oil pan so took it off and nothing suspect. sorry this post is so long but don't want to waste anyones time being vague and some information about my truck is obviously necessary. moving in a month across town and really wanted her to be useful. thanks in advance for any help and expertise.
