guages from an 85 into 87
hinkv10
ct
craig
v10
I have a 87 v10 and all of my guages work except the oil pressure guage. The po put in a mechanical oil pressure guage. My case for the gauages, the white plastic piece is broken where the shift indicator screws into on one side. Therefore the shift indicator moves around a bit and isn't always that accurate.
My question, what is different between the guages on a 85 and 87? Can I just take the case off the replacement guage set and transfer it over to my guage set. I should mention that my guages has a clock which I don't really care for. I'm unsure of the one from the 85. Thanks
hinkv10
ct
craig
v10
perfect! thank you
