Grille Bezel Nuts?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Will these break if I undo them with a ratchet and socket, or is there a trick? I snapped the studs on the park lights.
Those are usually fine unless badly rusted. Those don't look badly rusted.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I got two of them. One is in a really awkward place. How do I pull that piece of trim off? It's stuck on there pretty good.
brewster21
Iowa
Jason
I would try some sort of lubricant like wd40 or some type of lubricating or penetrating oil and then try to unbolt them, if I am correct they are just lightweight hollow nuts on a plastic thread so really if you wanted to, you could cut them off with maybe a tin snips if you put some pressure on it
Sent from my LGUS991 using Tapatalk
brewster21
Iowa
Jason
If you use the tin snips try to avoid messing up the threads on the plastic bolt
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I got it! WD40 and a small ratchet did the trick. Thanks, guys.
Chevy454-350
