Glove box is a bear to open...
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
So the locking/latching mechanism works by itself but the entire assembly spins in place when its open. And when its closed instead of releasing the latch it twists...
Seems as if a detent is missing like the ones on the door locks but it much be a different style.
Anyone had this problem before?
Thanks
Chevyguy
Eugene,OR
Clayton
V20
5.7 Litre
Thanks
Sounds like you need to get another whole assembly. I had to do this twenty years ago when I had my 73 K-5 Blazer. I got one from a wrecking yard and took it to my neighborhood locksmith who cleaned it and rekeyed it for me.
Clayton
Corpse
Toronto, Canada
Ramon
K5 Blazer
6.2 Diesel
I can't imagine why i would need a whole new assembly. Everything works it just needs some tension to hold it to the glovebox.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
This is all I have to offer, haven't really looked at mine...
attachment.php
robert8096
Goose Creek SC
Robert
The lock nut in post 11 in the above mention thread needs to be tightened. Use that thread and put a little blue lock tight on the locknut threads and you should be go to go. I don't remember seeing any kind of keyway on the glove box door for the lock to fit into to help hold it in place. I have a door at home without the lock if you want a picture of the lock hole.
Bfortune1000
B.C.
Brandon
mines been ******* me over to when i unlock it it falls on the floor and it is so god damn hard to get back closed have to get perfect angle and slam it
robert8096
Goose Creek SC
Robert
Sounds like time for a new glove box.
FRANKENTRUCK
By The Sea
Pierce
C10 Deluxe Stepside C10
350 with 350 Turbo transmission
Does anyone if the glove box replacement from LMC are worth the buy? Or are the hinges cheap brittle plastic like the factory ones?
Do yourself a favor and upgrade to a steel or brass hinge from Home Depot, there is a write up in here somewhere about it.
RETRO MODS ROCK
FRANKENTRUCK
By The Sea
Pierce
I already did that with cabinet-type hinges but I was hoping for something better. It seems odd to me that LMC has not come up with just such a hinge upgrade for these glove boxes considering just how sorry and cheap that they originally were. Before I fixed mine whenever I would open it that glove box would take a swan dive to the floorboard and infuriate me every time. I sometimes wonder how many years those cheap plastic "hinges" would average before breaking.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
My 84 and 87' are both going strong, hinge-wise.
rainyraven
wilhoit az
Ben
k10 cheyenne
I think they work ok but normally people over open them.. and when somebody does that a few times it can be the death of the plastic factory hinge
I did just find one on the donor truck I got and I put it on.. so far its good.. I might regret this view point latter if it breaks since I had a metal one somebody made
8T6K5
AZ
L98 350 TPI
I bought the replacement GB liner from LMC. Just like OE, it uses a plastic hinge. Also bought a new lock, from Classic though, came pre-assembled with new keys. Those things can be a MF'er to install.
Brianall
