wanderinthru
- Jul 23, 2020
- Mid Point Route 66
- Shakey
- 81, 70, 75, 84, 89
- K 10, C 30, K 20
Im personally feeling the choke is not correct. I run and eddy 1406 and had the same issues till i adjusted the choke.
Have been wondering if or how much altitude has to do with this? If I recall right, the lower the atmosphoric pressure the lower the boiling point right? Being at 4200 feet, putting a little 3/8 inch thick phenolic spacer took out 90% of the problem, Yet where you are the problem doesn't exisit, with proper carb settings. I've no idea the altitude of the OP but being in Montana sure could be alot higher than Penn. Dunno?? Just fighting my own ignorance????
