Gearbox for 85 k10
silverscottsk10
trafalgar indiana
mike
My gearbox took it's last turn the other day
Major failure from the rear as it leaked all my ps fluid out
It's 152 from oreillys
Anyone have one cheaper?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Leaked from the rear as in the input shaft by the rag joint??
If that's the only issue, NAPA sells that seal kit for just a couple dollars, and it's easy to install without removing the steering box from the frame.
silverscottsk10
trafalgar indiana
mike
Yes
Idk much bout gear boxes
I just know it was a hell of a time without ps
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
NAPA p/n 7-180 I paid $6.59 plus tax.
It comes with instructions.
Remove the rag joint pinch bolt (7/16" 12 point) and with a prybar, slide the rag joint and steering shaft upwards to clear the input shaft on the steering box.
Make a reference mark on the steering box and the part the large locknut is on (the adjuster).
You don't want to reassemble it any tighter than that existing adjustment, unless it's really worn inside.
Using a drift punch and hammer, loosen the locknut, and unthread it from the steering box.
Now, VERY IMPORTANT, as you unthread the input shaft adjuster/seal assmbly from the steering box, make sure you keep pressure on the inner shaft, do not allow it to back out of the steering box, or you will end up doing a PITA complete disassembly and reassembly of the box.
I just did this job on my truck, and it was much easier than I had anticipated.
Just go slow and be careful.
There was a slight difference between the instructions and my box as for the parts to install to replace the seal, but it will be obvious to you what to do when you get it apart.
Altoids94
Vancouver, BC, Canada
Kevin
Sierra Grande 1500
Keep this updated, I have the same leak. Thinking of tackling it also.
