Fuel line questions
81squared
Pawling NY
Marc
scottsdale
Looking to cut my OE hard fuel line that goes from the fuel filter to the carb so I can run rubber hose to my edlebrock carb.
Would a 3/8 fuel line slide over the existing hard line after I cut the flare off ?
I assume 5/16 would be to tight ?
I currently purchased a 3/8 fuel filter and a 3/8 inlet Banjo fitting for my carb.
Any help would be appreciated
dsteelejr
Hudson, WY
Cheyenne super C20 camper special, Sierra K25
I did the exact same thing you are doing about two years ago. It will work.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
simple way to measure stuff like this is to use a open ended wrench , kind of like a go no go gauge. the 5/16 will not fit over the fuel line , the 3/8 fits and a 9/16 fits loose. there fore you have a 3/8. I use this on bolts all the time but works with hard lines too.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Personally, I chose to put an inline filter in the hose that runs from the frame hard line to the pump. When you change the filter the fuel that drains can be collected in a pan, instead of draining over the engine. This also protects the fuel pump from any rust in the tank.
Hard
