fuel cell with or without foam?
RangRayy
Kansas City, Missouri
ryan
r10
searched and searched but cannot find a valid answer. i know the foam is for safety and i thought mainly for strip use and a requirement for drag cars. i however am running a street only truck. for street do i need the foam? looking at an aluminum cell with probably a sending unit. stupid question i know and i hate posting redundant questions but i have searched google and no one can give a definitive answer.
74 Shortbed
The foam acts like a baffle and prevents fuel from sloshing around, good to have on the street, BUT I don't know if it would hold up to ethanol crap, if you run good gas then no problem..
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
i have a 15 gal fuel cell without foam in my 74 with a sender in it with the foam the gauge sender will not work the foam will keep the float in the full or empty point will not rise and lower with the fuel my gauge dose not bounce around at all till it is below 1/4 tank I got it off ebay I hope this helps
RangRayy
ryan
r10
yessir it does. i was debating between a 15 gal or 20 gal tank. what brand cell is yours?
74 Shortbed
That's real easy to fix, just cut an area out in the foam blocks enough to clear the arm and float works great, did that in a neighbors Chevelle about 8 yrs ago, still working good.
amarti 201495
