Front yoke hitting crossmember
Cemack
Alberta Canada
K15
Hello, I just pulled my transmission and transfer case and replaced the seals. Sm465 and np205. My front yoke is now hitting the transmission crossmember when I engage 4x4. I did replace the transmission mounts with new ones from LMC. Has anyone else experienced this? How much clearance should I have normally?
here is 77 to d44
worn obviously. i could see too short of an adapter maybe
I JUST REalized your adapter is very flush to your t case with how close the mount is.
here is my og 1980.
Does your tcase have the double cardan
looks like you have just a simple flange and 1 joint to straight shaft?
maybe wrong size? can we get another angle?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Transmission mounts from lmc appear to be too short causing it to hit.
perhaps 2wd trans crossmember mount instead of 4x4 trans adapter crossmember mount? i hear they are the same up to 80 soemthing
Everything looks to be correct. Did you put the crossmember on backwards?
Loco Hills
K-30
Stupid question,but is the metal case or outer shale present over the top of the polyurethane bushing on your cross member?
If so,I’m not sure what could of changed?
Looks like there’s enough thread on mounting bolts,you could use some 1/4” plate for shims under the feet of the adapter.
Loco Hills
K-30
Maybe a better option
THIS. If you notice on mine, there is a little dip in the outer lip, it drops lower on front side(prob for that reason) and would be 100% reversible as long as the holes are centered on the crossmember(probably are)
Probs wouldnt hurt to undo engine mounts and that mount when repositioning to take tension that might be on your crossmember. if you replaced the pads and it was worn, it might have naturally over time turned down, and putting new pads on would "twist" the engine mounts and put a constant pressure that would be amplified by driving. So make sure no binding
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
This is what he is referring to. There is a dip in the cross member for clearance. This photo is just for reference, since I can't tell which one you have.
Cemack
Alberta Canada
K15
Maybe I put it on backwards? There was one fixed hole for the mount and one slotted hole. I have the fixed hole on the drives side. When I reinstalled it, it looked like there was only one way it could go. I'll have a close look at it today. Thanks for the advice
Cemack
Alberta Canada
K15
I'll have a look at it today. I never noticed that recess in the cross member when I was reinstalling it
Cemack
Alberta Canada
K15
Everything on the truck is original in that respect. That crossmember had been on that truck since I bought it in 1997. Four wheel has never been an issue before now. Like Bucket said, it could be on backwards so I will check that out
HOTFOOT
northwest ct
michael
gmc k3500 srw
On my k3500 the slotted hope is on drivers side
mick84
