front wheel bearings question
peyton
houston, tx
peyton
c20 suburban
diesel 6.5l na
my 1986 c20 diesel suburban needs the bearings repacked but it is 8600 gvwr. this means the bearings and seals to this vehicle are unfamiliar to many of the people at the local parts houses. can anybody give me the gm or acdelco numbers for the front bearings and seals? thanks,
peyton
idahovette
Weiser Idaho
Perry
K20-K10
According to Autozone inner is a set 45 outer is 15103S brg 15243 cone 8974S seal. Better take yours with you to compare
peyton
houston, tx
peyton
c20 suburban
diesel 6.5l na
thanks idahovette. i was hoping to avoid that.
peyton
idahovette
Weiser Idaho
Perry
K20-K10
The reason for taking them with you is NAPA and Autozone have conflicting numbers for the inners Zone says set 45 for the inners, NAPA says set 35, so there is that. Both say the same for outers. It's a game!!
is there a difference in spindles for 2wd suburbans? Maybe check to see if they list a different options for spindles or if there is a RPO from a HD front for that year or yours specifically that could possibly call for a different bearing.
aaron06
