front rubber brake line replacment
kenn
detroit
ken
c10, k10
Any good tricks to remove front rubber brake lines? I have installed 4 inch lift, and found front brakes lines to short. when I took a closer look it seems they have some dry rot in the rubber, so I bought braided lines (extended) I have been spraying old connections for the last couple of days, going to tackle tonight.
Its a great spot , cant see, and headers are blocking any chance at access was hoping to push line thru the hole, and get from outside of frame. Any advise ?
I’m not lifted, but I took my wheels off to do calipers, pads, and a proper bleed. Turn the wheel to full stop where the side you’re working on faces you, and it’s pretty easy work.
