Front lighting harness for 83-87 V22 RPO
davetyp
High Springs, FL
Dave
Converting an 83 K20 from two headlights to four headlights. Have the core support, bezels, buckets, and all the rest of the hardware from a donor truck. Also have the front lighting harness -- but it's in pretty sad shape. Cracked insulation and a few mangled connectors. Is there anywhere to get a new replacement front lighting harness for the V22 RPO code for the 83-87 year models? At least I think thats the right RPO for the quad headlights. Thanks! (Sorry if this is the wrong sub-forum, but the Wanted forum says I don't have permission to post there. Weird.)
yes. there are also places that sell the harnesses but with relays and wired more appropiately for brightness and taking the current away from the switch
ali_c20
Austria
Alexander
C20, K5
Go for a relay harness, I've put them in all my cars and trucks. Brighter headlights and less load on the old wiring and switches. You can diy this harness, it's easy and cheap. This is the setup in my k5 with painless relays.
Moderator
You need a minimum of 50 posts to start a new thread in the classifieds. It's simply just to deter scammers.
Are you doing a 100% factory stock type restoration? If not, you can modify your original harness to work with the 4-headlight setup. It's a pretty easy job.
davetyp
High Springs, FL
Dave
Maybe I missed 'em, but LMC, USA1, etc don't have any for the 83 and later year models.
davetyp
High Springs, FL
Dave
Not even remotely stock. Yes, could read the schematic and mod the existing harness with new lamp sockets. Laziness says otherwise. :)
davetyp
High Springs, FL
Dave
Good idea, but will be using LED lamps, so current draw through the switch isn't as much of an issue -- I think. Wary of introducing more moving parts to the system, seems like more potential points of failure.
Moderator
That's the beauty of it, you only have to add 2 lamp sockets, the existing two will work just by repinning them. Think of it as being half the work you expected, lol.
ali_c20
Austria
Alexander
C20, K5
davetyp
High Springs, FL
Dave
Good point, I remember reading about repinning the existing two sockets. You know what, that's the way I'm going to do it. Thanks for the encouragement!
davetyp
High Springs, FL
Dave
Wow, thank you! That's... embarassing. Saw those before, but for some reason that is now unclear to me, thought they wouldn't work. Apparently that's why talking to other people is usually beneficial. Thanks again.
dlw3
brooklyn
dan
c-20 suburban
6.2 diesel
dlw3
brooklyn
dan
c-20 suburban
6.2 diesel
I got into an accident and damaged my core support I have a 82 rpo v-22 with the 4 headlights 2 on each side stacked…im looking for a new core support…I can’t find a oem one so I’m gonna go with the amd premium…I would get the one that is set up for dual headlights right? It’s just in pics the single and dual supports look the same …I was maybe figuring they use stock photos
Any pics of a dual core support would be appreciated or a part number..thanks
Rangelloz
