front hitch mount
m1000snopro
Palisade, Co
Joshua
I have been exploring this idea of trying to build a way to put a hitch mount on the front frame of my truck and have the receiver part sitting right behind the license plate. that way I can slide in a winch when needed, I was wondering if anyone had done this before
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I'm not sure if anyone's gone right behind the lisence plate. I know someone had done a front mounted reciever hitch on their square I can't remember who it was though.I want to do the same thing for a winch too.
m1000snopro
Palisade, Co
Joshua
it really doesnt have to be behind the plate i just thought it would be cool to keep the clean front end look and then be there when needed. i think im going to get some square tubing and try and bolt it in between the frame and weld on a reciever
yevgenievich
Viktor
sad
very sad
less sad
I have one installed on my suburban. It mounts using the bumper bracket holes on the frame. It sticks right under the front bumper
It can be seen in the following picture
chengny
I did this:
Here is a picture that shows the receiver without the winch (I'll try to find a picture with the winch mounted)
Used the front receiver to mount a Mile Marker 18000 lb winch. It worked great.
One day when I didn't have the winch mounted - I had to call in outside help:
m1000snopro
Palisade, Co
Joshua
I did this:
One day when I didn't have the winch I had to call in outside help:
just so im 100% clear it is just mounted on that cross bar right there? i have that same bar i was wondering if it was strong enough but if you have it mounted there only and pulling from a ditch i would think it is strong enough
chengny
Yes, that crossmember is extremely strong in the front/back axis. It is shaped so as have high resistance to deformation in both directions. The top flange is bent backwards and the bottom flange is bent forward. Here are some images showing how it is formed:
This is how I mounted mine:
m1000snopro
Palisade, Co
Joshua
perfect! that's what I was looking for thank you, looks like I got my project set for next week
eatfood
