Front drive shaft help!!
PRECISION
CT
Ken
I installed a 12" superlift suspension on my 86K10..
rear drive shaft i had lengthened and works fine...
front driveshaft length and angle were obviously a no go!
installed the 1" spacer at front of the 208 transfer case that was a recommended part to clear crossmemeber and will fix length prob, however the angle for the CV is WAY to much to operate correctly even after grinding the tabs...as superlift suggested lol...
what are my options? :Insane:
I think the only good option is to call one of the high end driveshaft shops that do a lot of mail-order stuff.
highdesertrange
kalifornia
mike
k30
I have to ask, why? why do you need a 12 inch lift? highdesertranger
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Double cardan u joint?
thinchey
