Front body/radiator mounts RELOCATE?
KennedyHill
Louisiana
Joey
I’m putting an ‘87 body on a ‘74-‘75 frame. The ‘87 is long wheel base and the older one is short. I wanted a short bed.
The older frame has more of a rounded nose while the newer frame has an open, slanted nose that bolts up to a bumper bracket. As you can see in the pictures, there is about an inch difference from center to center and the body mounts are different. If I keep the old ones, I’ll have to modify them to receive the new style body/radiator mounts.
Here’s my question: Does this really matter? Do I need to adjust the mounts to make up for the 1” difference? Will this affect my fender and quarter panel location?
KennedyHill
Louisiana
Joey
It’s probably not quite an inch difference
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I wouldn't use that rivet as a measurement point. Can't say for certain.
I would measure center of the body mount to the fender mounts on the cab or to somewhere on the firewall
scape
Springfield, MO
Shannon
LS
Yes it will make a difference. I just swapped an 85 long bed body over to a swb 79 frame. I used the 85 core support brackets and found out that I had to redrill the holes for the brackets to get it all to line up. I would recommend getting your front clip on and somewhat adjusted and then mark your core support bracket position. I also tried the method of cutting the front bumper brackets instead of the frame rail. No luck getting the bumper to align, so i cut the frame like the later models and the bumper fit perfectly.
jw23655
