Ford Trash Talk Thread lol
the f150 has a broken steering column somehow and the thing also dog tracks now. Unrelated. but :O
scrap--metal
MN
Calvin
'85, '81
K10, K20
Ford Tells 39K SUV Owners to Park Outside
So far it hasn't developed a repair for the fires, which appear to start at the back of the engine compartment on the passenger side.
Of the 16 fires, 12 happened while the SUV engines were turned off, Ford said in a prepared statement.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
Ok, yes I have to admit a few good things came out of Ford, and I agree with your example.
My current square is at 231K on it's 350. Setting aside all synthetic oils for a second, the one additional thing I will say is that standard "dino" conventional oil, got leaps and bounds better in the 80's and 90's. Mainly in their ability prevent deposit build ups, and to leave a film to prevent dry starts. So if we go back in a time machine for second in 1975, it was much more likely for any engine to wear out faster because of the oil that was around in those days. Another thing, anyone remember the awful deposits that Pennzoil use to leave behind, it use to be said it was small amounts of coal in the oil building up over time. I have no idea how true that is but I do know at least into the late 90's / early 2000's area we'd see engines all slugged up because of Pennzoil use. Surprisingly enough a poorly adjusted choke if left badly out of adjustment for to long can take a toll on engine life as well. A pull off not working can cause cylinder wall wash down at every cold start, do that over and over again and it can do a lot of initially unseen damage. A choke to lean might cause the driver to pump the crap out of the gas and then rev it excessively high to keep it running. Lot of variable for sure!
As far as the 4.3 thing is concerned, I worked at one point at a place that had a fleet coming to us with a bunch of Astro vans, and unlike most fleets these guys took care of their rigs. They had many make it to high mileage 200K+, the biggest down fall to the 4.3 IMO was the spider injection. and the flat top distributor caps had issues with the cheaper aftermarket ones but those issues were not exclusive to the 4.3.
I'm still working my way through the thread, so it may have been mentioned, but Pennzoil and Quakerstate (among some other brands) are Pennsylvania crude oil origin, high Parrafin content, that's what caused those deposits. Gulf oil (from Texas and the Gulf of Mexico) are Sulfur based and the worst thing to deal with is a possibility of sulfuric acid.
Something that has stuck in my head since auto shop 1971-73.
84-C20
Chevrolet
I wonder where Pennzoil, and Quakerstate get their crude from these days. Is Quakerstate still around anymore?
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
84-C20
Chevrolet
@mtnmankev you got me wondering so I looked it up. Certain online retailers show Quakerstate, but their company website only shows a handful of shop in my area that sell it. I would assume they are buying it in bulk.
Pennzoil's website shows mostly Synthetic flavors of oil but they do like one blend. So I guess that was their solution. Given that companies reputation it is surprising it's still in business.
Jeremy89
